2003 silverado gauges
Discussion in 'General Chevy & GMC Pickups Talk' started by george405, Jan 29, 2006.
  1. george405
    george405 Member
    Hi all I have a 2003 silverado, the gauges are irratic, the speedo sometimes works normally then it shows Im doing a 120mph, the temp guage sometimes dont work, and also the oilpressure comes and goes not correct, is there something that controls all of them,a computer or what could be the problem? thanks, Im lost when it comes to electrical diagnosing....
  2. eugene68
    eugene68 Member
    phoenix u.s.
    I had a 1992 gmc that had similar symptoms.. it turned out that the guage cluster "plugs" in. all in one big plug like a module in a computer board.. it is is loose, or the connections are dirty it will show eractic readings.. also a low battery will sometimes give similar symptoms because all the electrical sensors run of a certain voltage.
    hope this helps you .
    eugene
