216 upgrade ?
Discussion in '1947-1954' started by jackson, Dec 30, 2010.
  1. jackson
    jackson Member
    Gold Bar, Wa.
    Does any one know how to convert a 216 to full pressure oiling & insert type bearings? Or have a link to this info? Would it even be worth while $$$$$ wise? Thanks for any info. any of you might have. Terry.
  2. brit 50
    brit 50 Member
    Essex England, the motherland
    Nate
    Time for Nate to step up to the plate I think:D
  3. DeadZoneTruckin
    DeadZoneTruckin Member
  4. coilover
    If you go back a couple pages to my thread on 12-06-10, titled "216 anyone", you will see where this man is trying to give away a 216 that's already been converted to full pressure and bearings. I told him he could use one of my trailers to haul the entire drive train up to my storage area but he has never come to get it so it may have gone to someone else. I have his name and address, somewhere, but no phone number. He lives in Sunnyvale, Texas, which is on the opposite side of Dallas from me and about 60 miles away so he probably found a closer place to get rid of it.
  5. ronaldg
    ronaldg Member
  6. jackson
    jackson Member
    Gold Bar, Wa.
    Evan, I saw your thread & it got me to wondering why couldn't/shouldn't I do that. I have a 216 to put into my '52 (a runner, got it cheap)but I'm still hesitant to use it due to the oiling & babbit bearings. Anyways I was just curious about the feasibility/ cost.
  7. jackson
    jackson Member
    Gold Bar, Wa.
    Thanks Evan & Ron.
    Terry
  8. Guest5979
    Guest5979 Guest
    Becks charges about 5 thousand dollars to convert one I spoke to him myself about converting me 216 sometime ago.
    Robert
  9. federale
    federale Member
    Washington C.H.,Ohio
    $5000.00 ? WOW choke cough wheeze! You could build one hella engine for that and keep the 216 for garage decoration.
  10. willardgreen
    willardgreen Member
    Dixieland!
    engine upgrade
    You have the engine out. Go get a 261-ci engine and you will never regret it. You will also have to change the oil pressurre gauge to the 60-psi gauge. Put on the offy valve cover and most will think you have the 216. If you fix the 216 and then get to drive a 261 you will feel almost as bad as I did when mine burnt down with no insurance:(. With a little more work you can have the 292-ci.
  11. vwnate1
    Babbit Pounders !
    I just can't see this .
    For less $ you can have a 235 or 261 .
    One fellow here just did a super careful overhaul of his 216 and balanced everything to zero grams and did the head work I suggest , he runs it very fast indeed with " Target Lubrication " and has no worries but it's still slow so why ? .
    You makes your choice and you pays your monies .
