I bought an unknown 292 from a '66 C/30 that had been sitting for a few years and was stuck .
To day I took it apart and was able to easily knock out the two stuck pistons .
Several of the connecting rod bearings were slightly " wiped " showing copper through the babbit .
The crank journals looks pretty good , I'll see if I can find some Crocus Cloth & wet polish the journals .
Right now the rod bearing journals measure out @ 2.0875"
Bore is @ 3.9080
I used an electronic caliper .
The block casting # is 3851659 , this breaks out to be a '63 ~ '79 Chevrolet 292 .
The date code is K174 , I've forgotten how these break out .
I need to find a 3" ball hone to run in the ridge free (! sweet !) cylinders .
I'll be replacing all 6 pistons and prolly the cam too , the lobe tips look good but the heels show seriously off center wear , I've not yet pulled the tappets , I imagine they'll be worn out .
This engine looks like it was gone through not long before it was taken out of service , hardly any sludge in it and the bearings and piston skirts look very good apart from the narrow wiping in the middle of the load surface , typical if the rods were not re sized during the last freshen , also very common when the operator over speeds this long stroke engine .
So , I need info in what the bore and rods are , std. or oversize and what oversize ? .
Also , what date was it built ? .
Any and all comments are welcomed , this engine will replace the ailing 250 I6 in my '69 C/10 now .
TIA ,
Bore is @ 3.9080
TIA ,
![IMG_0791[1].JPG IMG_0791[1].JPG](https://talk.classicparts.com/data/attachments/12/12749-f3d866f2cfd632b78d5c7ac38b18e64e.jpg?hash=89hm8s_WMr)
![IMG_0792[1].JPG IMG_0792[1].JPG](https://talk.classicparts.com/data/attachments/12/12750-b0ea64190068571e3936cf882b705a6b.jpg?hash=sOpkGQBoVx)
![IMG_0793[2].JPG IMG_0793[2].JPG](https://talk.classicparts.com/data/attachments/12/12796-d6e64d033019f78da085fafd26c32666.jpg?hash=1uZNAzAZ94)
![IMG_0794[1].JPG IMG_0794[1].JPG](https://talk.classicparts.com/data/attachments/12/12797-df34e9df2652b16af7d9736dcffdd150.jpg?hash=3zTp3yZSsW)
![IMG_0795[1].JPG IMG_0795[1].JPG](https://talk.classicparts.com/data/attachments/12/12798-968b7afc034d417f31d0d4db80507a11.jpg?hash=lot6_ANNQX)
![IMG_0799[2].JPG IMG_0799[2].JPG](https://talk.classicparts.com/data/attachments/12/12799-47d1176e8488cddc06335585ae2207ea.jpg?hash=R9EXboSIzd)
![IMG_0796[1].JPG IMG_0796[1].JPG](https://talk.classicparts.com/data/attachments/12/12800-34b7784e1ef8aec9dceff8c47ad40a49.jpg?hash=NLd4Th74rs)
![IMG_0797[1].JPG IMG_0797[1].JPG](https://talk.classicparts.com/data/attachments/12/12801-57271c5e2c46df65a71afba9b30971e0.jpg?hash=VyccXixG32)
