2wd to 4x4 can it be done?
Discussion in '1967-1972' started by 71GMC, Aug 6, 2003.
  1. 71GMC
    71GMC Member
    Angola USA
    I just piched up a 71 GMC long bed. I love the lines of the truck.
    I was looking at the frame on a 4x4 and my truck and they seem to be the same. I was wondering if anyone knows if it is possible to make my truck into a 4x4. Has anyone tried, can you give me any pointers or is it a lost cause.....
    BTW: Great forum, i'm new to the site, but have found in the past these foums are great for information exchanges. Keep up the good work.
    -Ben
  2. rodster
    rodster Member
    I have converted a '71 stepside to four-wheel dirve. The main parts u will need is the spring shackles for the front and back of the front springs,and another shackel for the rear springs for the reason of it being shorter. I myself just used a lift block to make up the difference in height. In the rear of the front springs u will have to cut a hole on each side of the frame for the shackel go thru and bolt up. U will also need some new steering parts linkage,box?,trans,transfer case,drive shafts,front and rear ends,wheels if your is not already 6 lug. Trust me u would be far better off to find a junked 4-wheel drive truck frame and transfer your body onto it. Then the fun will begin because the vin numbers on your title are for a two wheel drive truck and you now have a 4-wheel drive truck. Now you have to go to the DMV and get a salvage title for your truck if you can can even get one in your state. P.S Been there, done that, wont do it again to much work.
  3. chevypu1968
    chevypu1968 Member
    north vernon
    im turning a 1968 1/2 ton 2wd into a 3/4 ton 4wd i want to just change the frame but 68 4wd frames are hard to find what year frame will work?
