3/4 ton - 1 ton rear axles in '67-'
Discussion in '1967-1972' started by jlh9375, Aug 25, 2004.
  1. jlh9375
    jlh9375 Guest
    I found a 1 Ton Dually Axle in a local junkyard, I intended to swap with my '71 GMC C-20 (Dana 60). Due to the Right hub bearing siezing to the adjuster AND lock-nut, Stripping the threads on the axle-tube in the process.
    It was under a '67 or '68 Chassis/Cab with a dump bed. After making a deal and upon delivery I noticed that It Was NOT a Dana 60, (Or any other series Dana that I've seen). I've talked to everyone I know and all I have got was a possible ID of an Eaton Unit.
    If any one Can Help I would really appreciate it.
  2. robert71C20
    robert71C20 Member
    usa
    RE: 3/4 ton - 1 ton rear axles in '
    If it has a 10 bolt rear cover, than it's an Eaton rear end.
