3/4 ton rear end
Discussion in '1967-1972' started by Mwallis783, Aug 25, 2003.
  1. Mwallis783
    Mwallis783 Member
    I have a 68 3/4 ton chevy with 8 lugs. The gear ratio is very low, does any one know if there is a higher ratio avaiable for this big rear end
  2. CrashBob
    CrashBob Guest
    [updated:LAST EDITED ON Jun-24-04 AT 12:49 PM (CST)]Hey,
    I'm in the same boat as you with a '67 with 4:56 gears. I'm looking at replacing the TH400 with a TH700R4 overdrive trans and changing to a 3:70 ratio. There are several sources for these gears, get on Google and start looking.
  3. cowboy
    cowboy Member
    Just lookin some of the 4x4 mags and you will see gear sets and the vendors that sell them and they should have some gears for your axle.
    cowboy
  4. bvansic
    bvansic Member
    Minneapolis usa
    I'm having the same issue my 70, take a look at the drivetrain superstore (www.rivetrainsuperstores.com), they have quite a selection and the site is pretty helpful determining the correct ratio.
  5. nsula_country
    nsula_country Member
    Check your address, it is www.drivetrainsuperstores.com
    79 C20 Bonanza
    350/400 4bbl Q-Jet
    3.73 14-Bolt Corp.
  6. albyneau
    albyneau Guest
    Then most likely what you have is an Eaton- big removeable pumpkin *AND* an inspection cover. Lowest numerical ratio available was 4.10's. If you're mechanically inclined, or have a buddy who is, the cheapest way around this is to swap in a '73 & up GM corporate 14 bolt. There's SOOO many out there they're practically free, with ratios down to 3.20's. This is all moot, of course, if you're planning to swap the tranny to something newer/OD'd... personally I'm doing BOTH.;)
  7. tech1
    tech1 Member
    there is a lower ratio then the 4.10 and it is the 4.56 that were used in 4x4 trucks
  8. albyneau
    albyneau Guest
    Well, yes- and my '61 1.5 ton has 5.13's (along with a 2" rear sway bar- LOL!), and there's more- but I don't remember them all... but please note: I didn't say lower gear ratio(bigger #'s)- I said lower *NUMERICAL* ratio (smaller #'s)
