Hey I am new so let me start by saying Hi.
I have a 91 suburban with a blown motor, so I got a "new" engine, casting #3970010 68-79 350. everything has gone smooth until I tried to bolt the intake on. The new block was a carb engine mine is FI, I want to keep FI, the intakes are the same except the middle 4 bolts, 2 on each side are at a different angle on the intake, the 68-79 block are all the same angle the 91 all except the middle 4 are the same, is there an adapter plate I can get to make the carb intake work with FI?? If none available can it work at all?? If so I could have a plate machined. The carb intake is 4bl the FI is 2bl. I ground the bolt holes so I could make it work, I would have to have a spacer machined though, but I dont have enough room to get a long enough bolt in.
Thanks in advance for your help
