355 Gear conversion/New tires
Discussion in '1947-1954' started by smoloney, Apr 11, 2019.
  1. smoloney
    smoloney Member
    Cincinnati, OH
    Had my conversion done for several years now, standard 3 on the tree. Is there away to adjust/correct the speedometer?
    Thanks Steve
  2. Bill Hanlon
    Morris Ranch TX
    The easy way is a speedometer ratio adapter. Just type "speedometer ratio adapter" into your favorite search engine.
  3. smoloney
    smoloney Member
    Cincinnati, OH
    Thanks Bill! for the life of me I couldn't find it, that helped I contacted a guy on ebay. Steve
  4. coilover
    Go to TCI "speedometer gear calculator" to get the correct speedo drive/driven gear formula and eliminate any ratio corrector. Your speedo is reading too slow now so what we do now is to use a gps to find the PERCENT difference between indicated speed and actual speed and then use a set of gears that will read that percent faster.
  5. smoloney
    smoloney Member
    Cincinnati, OH
    I found one I just need to confirm the threads on the end of the cable that attach it to the transmission do you know if they are 7/8" x 18 thread ? Thanks! Steve
