I,m a little rusty when it comes to electrical problems. If I want to stay 6volt on my trk and put a 6volt switch on strg col. How or what do I do to make stock running lamps in grill work as turn signals too?
http://www.classicparts.com/1947-59-Double-Contact-Conversion-Kit/productinfo/47-905/ In order to change to dual contact assemblies for the front park lite/ turn signal, get these conversions from our host. They give you dual contact sockets for your lights, and then you can use dual element 6 volt bulbs. BTW, be sure to wire the brighter element for turn signal. Hope this helps. Bill
Why are you set on 6v? 12V is much easier to live with in the modern world, and is very simple to upgrade to.
