5.3 conversion to a 72 ???
Discussion in '1967-1972' started by hotrod29527, Feb 16, 2006.
  1. hotrod29527
    hotrod29527 Member
    conway us
    hotrod29527 has anyone put a 5.3 out of a 99 and newer truck in a 72 ci0 ?? ive got the motor just wondering how hard it is thanks :9
  2. Kp72chyensupr
    Kp72chyensupr Member
    Douglasville United States
    i don't know about a 5.3 but i am puting a 92 tbi motor in my 72 c10, the question is are you just using the engine or are you doing the full swap with fuel injection, electronic transmission, engine management and all. If you are just using the engine alone , i believe that summitt sells the intake, dist, and exhaust manifolds to make this engine carburated. either way i know early classic sells the motor mount kit for this swap.I also know that the folks at year one did a full swap in a 69 camaro and they even sell some of the conversion goodies as well. hope this helps and good luck, don't be afraid to try this, i know it can be done
  3. hotrod29527
    hotrod29527 Member
    conway us
    hotrod29527 i think i want to put fuel injection pullies belts everything !! someone told me to check with painless wiring thanks for the input:)
