I am still considering my options for a transmission. Most likely will go with a 700R4, but would also like to explore 5-speed manual options. Does anyone know of some options that would easily bolt into my 64? What about ease of clutch setup?
RE: 5 speed transmission installati well you might try looking in to keisler automotive. they have 5 speeds and 6 speeds and the site is www.keislerauto.com cowboy
RE: 5 speed transmission installati Please post any info you find on this subject, I am in the same position. I need a better tranny to handle more speed but I don't want to give up the clutch and a 5-speed seems the perfect choice. I have talked to a guy who says that the GM A833 w/ fourth gear overdrive is the way to go but have not had any luck finding such a beast in any boneyards or on E-bay. From what I understand the problem is not fitting the tranny in its where the shifter is located, is this your understanding also?
RE: 5 speed transmission installati The location of the shifter can be a problem. Sometimes they are too close to the front of the seat (depending on shift lever style) and other times the shifter seems somewhat low and away from the driver. I had a 57 1/2 ton with a 327-car four speed and this was the case with it. I have only had the original pickup 4-speed in my '64.
