51 3600 chevy rear brake hold down springs needed
Discussion in '1947-1954' started by Derek Johnson, Aug 31, 2022.
  1. Derek Johnson
    Derek Johnson Member
    In need of two rear brake shoe hold down springs for 51 chevy 3600 3/4 ton.
    ? Hithere ;
    Not the same as '51 ~ '67 Bendix brakes ? .
    Well, that sucks, I just checked Rockauto.com and they list pretty much everything else.....
    Anything like these ? : [​IMG]
    I looked at 3/4 ton 1966 Chevy pickup.....
    They also list hold down kits :
    [​IMG] Brake Shoe Hold Down Spring
    FVP FHH40602 {FHH4060-2} Info
    FitsFront; 11.15" X 2.75"
    orRear; w/ 11.15" Brakes
    $2.96
    Add to Cart[​IMG]
    CARLSON H40602 {H4060-2} Info
    orRear; 11.15" Brakes
    $3.89
    Add to Cart[​IMG]
    DORMAN HW4060 Info
    Rear; 11.15 In. x 2.75 In. Brakes
    $3.91
    Add to Cart[​IMG]
    RAYBESTOS H4016 Info
    FitsFront
    orRear; with 11" Brakes
    $5.42
    Add to Cart[​IMG]
    ACDELCO 18H4016 Info
    FitsFront
    orRear; with 11 in Brakes
    Out of Stock
  3. Derek Johnson
    Wow, thanks for all the info, that's just what I'm looking for..
    vwnate1 likes this.
    Please check carefully before buying .
    Chevy changed the brakes in 1951 and continued to use the Bendix brakes through the 1967 model .
    That being said, brakes are important so always triple check before reyling on anything I say .
    Be sure to to brake works in AXLE PAIRS !this means both sides of either end at the same time even if one side (for example) needs a new wheel cylinder or set of shoes .
  5. Derek Johnson
    Will do, Thank for everything!
    vwnate1 likes this.
