53 chevy 1/2 ton transmission
Discussion in '1947-1954' started by Jim G, Oct 1, 2014.
  1. Jim G
    Jim G Member
    I keep finding more challenges. In process of trying to fix the U joint on my 53 Chevy 1/2 ton I found that the all in one casing (U joint attached to transmission cover) has a crack and I may need to get a new casing. Or can it be welded. If not, any suggestions on where to find/buy a not too expensive casing. Ay yi yi!
    Jim G:rolleyes:
  2. gary1of2
    gary1of2 Member
    Valley Springs, CA
    Is it the transmission casing or the bell that is cracked. I have both. A real good welder can weld it as long as the now how to weld cast
  3. Jim G
    Jim G Member
    Univ joint/tranny
    thanks for your on-going help. what do you mean the "bell"? It appears the "cover" is all one unit.
    thanks.
    Jim G
  4. gary1of2
    gary1of2 Member
    Valley Springs, CA
    The bell as I call it slides on the end of the torque tube. It covers the u joint.
  5. Jim G
    Jim G Member
    chevy 1/2 ton
    Gary1o2: just so you know I sent you a private message.
    Jim G
