54 Chevy 235 oil pan gaskets
Discussion in '1947-1954' started by Neto84, May 22, 2019.
  1. Neto84
    Neto84 Member
    I’m replacing the oil pan gaskets on 54 Chevy 235 straight 6 the gaskets I bought are cork material brand feel pro. So my question is that the cork front and rear gaskets for oil pan don’t fit in the slot do I need to cut to fit if so what is the best way to get a straight cut
  2. RidesWithYah
    RidesWithYah Member
    Lexington KY
    The block casting number in your other post is a 58-62, which takes a different oil pan gasket than a 54 would.
    You want Fel-Pro OS5153C.
    And, don't forget to post pictures!
  3. Neto84
    Neto84 Member
    Thanks for the info I was about to begin installing the gaskets. So that means that is not the original engine on my 1954 Chevy 3100 series
