I'm working on installing a '55 235 into a '62 1 ton. The front motor mount brackets are different on the two engines. A '62 mount won't bolt to the engine. Will the mounts from a '55 bolt to the '62 frame? Should I swap out the plates ont the motors and use the '62 mounts? Burt
