57 Headlight Switch Wiring
Discussion in '1955-1959' started by LDO, Aug 22, 2011.
  1. LDO
    LDO Member
    MS
    I'm working on my 57 3100 and was wondering if anyone had a picture of the light switch and what wires go to which terminal. I've got the service manual but man that thing is a beast to try and read or make sense of.
    Many thanks...
  2. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    I got a cheat sheet at home, I'll post it when i get a chance.
    Bobby
  3. LDO
    LDO Member
    MS
    thank you sir!
  4. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    Here you go. You'll have to put the two pages together to get the big picture.This is what i used as a general reference, it answered any quetions that i had during the wiring process without incident.I hope this helps.
    Bobby
  5. LDO
    LDO Member
    MS
    Thanks for posting this.
  6. justplainray
    justplainray Member
    connecticut
    this may be helpful too
    wire colors don't match the diagram, but here's a look at the actual swithch.
    justplainray
  7. Red57
    Red57 Member
    Cypress, TX
    Similar wiring issue...
    I have an issue with my wiring on my 57 3100. Is there anyone out there that may have a picture of the original wiring of the ignition switch and the light switch along with the gauge cluster? There is a brown wire that comes out of the harness that goes to the gauge cluster, and I cannot figure out where it goes. Any help would be great appreciated. By the way, the truck starts and runs so I know its not anything with that. This is a 235, 3 speed (column shift) with floor foot starter.
  8. steve
    steve Member
    Virginia
    Pictures of light switch
    The wire colors should be correct except for the dome light.
    There is an Orange one in the center.
      File size:
      103.9 KB
      725
      File size:
      108 KB
      668
      File size:
      114.2 KB
      760
  9. stevenson42
    stevenson42 Member
    1959 Gauge cluster
    Steve
    Hello this is Bob Stevenson would you happen to have a picture or a wiring digram of the rear of a 1959 Chevy Apache gauge cluster?
    Thank you in advance!
    Bob
  10. steve
    steve Member
    Virginia
    Cluster
  11. vwnate1
    This Thread
    Is priceless ! .
    I hope all here know to copy the posts and photos , make a file of Service Info for your truck....
    10 years from now you'll be *very* glad to have these pix to print out and take under the dash .
  12. stevenson42
    stevenson42 Member
    Thank you so much!!
