59 chevy truck emergency brake, HELP!
Discussion in '1955-1959' started by toddstergto67, Feb 5, 2008.
  1. toddstergto67
    toddstergto67 Member
    when i built my 59 chevy truck, i put a 76 camaro sub frame on it so i could have disk brakes and tilt colum. i also put the camaro rear end in it too, does anyone have any ideas on how to modify and hook up the emergency brake? i cant use the one that was in it, i have to have it for a inspection sticker, thanks,
  2. HOT RODDER 1932
    HOT RODDER 1932 Member
    Oregon
    p-brake
    Lokar sells several different models of p-brake levers and pedals. Either way you will have some fabrication to do, but they use the GM type cables that will match up to the rear end.
  3. toddstergto67
    thank you, who is lokar? where are they located?
    Lokar...
    Is a company that sells Hot Rod stuff , if you didn't find them in an OnLine search , go to magazine rack and buy ANY Hot Rod oriented magazine and look in there for thier ads , pretty good stuff .
  5. toddstergto67
    thank you, i found them online.
