61 Chevy truck rear end.
Discussion in 'Truck Parts for Sale' started by smalltownspeed, Mar 29, 2009.
  1. smalltownspeed
    smalltownspeed Member
    Plano, TX
    A rear end from a 61 Chevy 1/2 ton truck. Was working great when pulled. Has backing plates, but no other brake parts, however, I may be able to round up some spare parts for my project for it. I think it has a 3.90 gear ratio. $75. I bought it to replace the rear end thats in my 59 truck, but found another good one localy that will bolt right in, so Id rather do that.
    Located in Plano, TX.
    EMail me at smalltownspeed@hotmail.com
    Thanks,
    Cory
  2. Flashlight
    Flashlight Member
    Ebrake parts. I have a 53' with open shaft
    My 53' has a 1960 235. I believe it has the open shaft rear end from it, also.
    Previous owner did not put in a ebrake. It has everything up to the original Yoke. the cables are cut. I think the ebrakes from your backing plates may work. Do you have the spreaders/Accuator?.
    Any advice the old cable had a triangular shaped drum attachment the backing plate I have, looks to be round shaped.
    Got a Carb bracket for the throttle and choke mount?
    Thanks,
    Flashlight
