There are companies that will sell a kit but I found it less expensive to get most of the parts from a donar truck. I have a '66 1/2 ton and used donar parts from a '79. I'm no authority but I believe you can use donar parts from '71 to '80 1/2 tons to upgrade from drum to disc on '63 to '70 1/2 ton trucks.
The upgrade on my project included power stearing. The donar parts I used are master cylinder, proportioning valve, knuckle/spindle, dust shield/backing plate, hub/rotor, power steering gearbox and pump, and all stearing arms. I purchased new brake pads, pall joints, brake line and hoses, tie rod ends, wheel bearings, etc.,(any parts that wear out). The donar stearing arms have a larger diameter and are stronger.
There is a fixed arm, on which the idler arm pivots, that must be bolted to the frame. The position is different than the old piece - so positioning and drilling is required. Also the stearing gearbox requires new frame holes and must be positioned with spacers. I'm told plates should be used on both sides of the frame to avoid cracks. I have not had crack problems but agree to the advice.
If you reply with your fax number I will supply you with a few articles articles that might be helpful.
Good luck,
