Ive been looking trough my chevy duty book ,and their is nothing in there for my four wheel drivetruck No it is not a napco conversion Is there a book for my truck.Iwould like to order some parts"If wife will let me"Where can i get a book.If chevy duty has one ,how can i get one.
Sorry we dont offer 4x4 parts for your truck you will need to find out what year your truck running gear is Rick tech2@chevyduty.com
I am in the same boat as you are my freind, I have a 62 Chevy 3/4 ton 4x4. Only help I can give you as far as axle parts is that you may have a Dana 44 in the front and a Dana 60 in the rear, my front axle has what looks like a ball and socket on each side behind the spindles, this is actually called a closed knuckle. If you are needing parts for this axle, go to your nearest Spicer dealer with the bill of materials number on the front drivers side of the front axle, the parts are available. Had to make a call to Dana Tech. myself. There are two sizes of the closed knuckle axle, mine was the smaller of the two, so you may get the wrong size seals the first time. Instead of king pins, yours will have tapperd roller bearings, match the numbers at a local parts house. It is a very simple axle to build. There is a parts site you can go to and decode your VIN, my axles have 457 gears, This site will tell you about your truck. E-mail me at jcyc69@atmc.net for more information. No I have not been able to find a book on my truck either, nobody even lists a 62 4x4, I am still trying to find a set of shocks. Hope this helps some. J.Corbett
you can get transfer case parts at blumenthals in oklahoma city you can give them a call at 1-800-262-9557 this is where i parts for my 66 3/4 ton 4x4, mine is also factory.chevy made a suplament for the66 year production year i use a factory shop manual for repairs and info this manual is for 1960-1962. you can buy this book after market. zgoat
