'65 defroster hoses
Discussion in '1960-1966' started by glenn, Oct 28, 2007.
  1. glenn
    glenn Member
    maryland
    i have a '65 C-10 stepside that had no heater...i found
    a '65 standard heater (with 1 knob that pulls & turns)
    my problem is...where does the defroster hoses hook
    to the heater...i know that the other end hooks to the
    vents on top of dash......thanks, glenn
  2. dvalentine
    The hoses connect to the defuser box below the dash. It has a handle that you throw to select defrost or heat. The control knob you describe is for the Thrift Heater. The knob controls the heat, ( by pulling out on the knob), and the 2 speed blower, ( by turning the knob.).
    If you are still missing the defuser box, check e-Bay orthe local wrecking yards.
    Val
  3. glenn
    glenn Member
    maryland
    defroster hose reply
    hi, thanks for the quick reply...cant imagine why
    previous guy took that end piece off & left the
    rest under dash....great looking panel...i'm just
    about finished with a '65 stepside...have 330 crate
    also....thanks again.....glenn in maryland
