Its all up to the person who drives thier truck,I have a1966 c-10 shortbed fleetside 283 v-8 new motor bored 0.030 with a 350 turbo automatic transmission that fine no problems.700r are good trans. for the mileage 700r are the way to goLove automatics love the 2 speed powerglide,3 speeds are great and is 4 speed granny lows had 4 speed granny low here while back those trans. are heavy as SH%T. They weigh a ton.
I just switched out my six to a V8 in a 62. Yours being a 65......you are lucky. You should be able to use your 3 spd, flywheel and bellhousing from the 6. You will need to change one or both of the motor mount towers on your frame. Pretty easy swap as far as changes go. I used a low mileage motor that just needed valve seals and a rear main oil seal change. Plenty of power for a stock small-- small block.............the 4:11 rear gears help too
