66 bed options
Discussion in '1960-1966' started by betamax, Nov 18, 2002.
  1. betamax
    betamax Member
    Will a Long stepside bed fit on a long fleetside truck? If so, I might want to put on long step on my 66 long fleet because it seems the parts are easier to come by. Thanks!
    ~Scott
  2. trustyrusty65
    trustyrusty65 Member
    Carson City U.S.A.
    Hi Scott, a long stepside bed should fit right on, since the bed is primarily held to the truck by bolts in the wood with an offset washer. Stepside fenders on the shortbed have braces to the front of the runningboards where they join the fenders that run to a hole drilled in the chassis with a nut(welded?) on the back. Longbeds are probably the same. Good luck!
    TrustyRusty
