66 C10 stalling
Discussion in '1960-1966' started by mahlew, Apr 8, 2011.
  1. mahlew
    mahlew Member
    Huntsville, AL
    I own a 1966 C10 with a 327 that will stall when I accelerate too quickly, either from a stop or while driving down the road.
    If I accelerate very, very slowly it runs fine.
    Could this be a carb or timing issue?
  2. drabo
    drabo Member
    Patrick AFB, Florida
    Yes it could be either or both. Check timing first then make sure your secondaries are operating properly when you go wide open throttle.
  3. mahlew
    mahlew Member
    Huntsville, AL
    Thanks drabo, I will try that.
    Will
  4. my2ndgirl
    my2ndgirl Member
    Hickory NC
    Could also be a vacuum leak
  5. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    accelerator pump ?
  6. T2vigil
    T2vigil Member
    Just north of Dayton, TN
    If none of those work check the fuel pressure at the carb - possible kink or restriction of the fuel line starving the carb.
