'68 chevy bed swap
Discussion in '1967-1972' started by millenium.208, Sep 22, 2008.
  1. millenium.208
    millenium.208 Member
    I have a 68 Chevy c10 4WD long bed w/steel bed, will the bed swap out with one from a 68 Chevy c20 2WD wood bed, without any redrilling of mounting points.
    Thanks
  2. Soba_03
    Soba_03 Member
    Bed question...
    Why doesn't anyone answer these?
    Ok the only difference it that one is wood and the othere is steel... The cross sills are still in the same spots and should bolt to the same location as the steel bed floor..in the locations were the bed bolts to the frame you will use longer bolts than in the areas where you are only bolting the wood down.. if that makes sence.....
