'70 GMC 3/4 ton, 2x, 402/400 AC Exc
Discussion in 'Trucks for Sale' started by TimT, Mar 20, 2006.
  1. TimT
    TimT Member
    Centerville
    Very nice truck. Original CA truck with Black Plates. I've moved to Ohio and am driving a big diesel truck now so this is just sitting. Has 125,000 original miles. Motor has about 30K on it and is very strong, with mild Crower cam, Carburator Shops DUI Distributor, nice dual exhaust, good brakes, quadrajet manifold and very rare quadrajet carb from '69BB Camaro. Truck has real nice blue and white paint, nice bench seat, good carpet and door panels. Original wheels and hub caps. AC blows cold. Only problems are right turn signal doesn't cancel, couple crack in dash, original cigarette lighter element doesn't work (plug is still hot so you can charge cell phone, etc.) just the ligher element doesn't work. Rear slider window doesn't latch/lock. This doesn't bother me because the truck has a shell/topper. Shell has real nice carpet kit inside too. Very little rust at all. In fact the rust that's on it has been there since I've had it which is about 10 years. Very small spot bottom side of door and rocker. The rest of the body is real straight. It's probably the nicest unrestored truck of it's age I've ever seen. It runs really well and will drive anywhere you want to take it. You won't be dissapointed and probably never loose a dime on this truck. In fact, it pulls harder than an original '70 SS396 El Camino I use to have. It had the 350HP motor. Anyhow, I'm going to list it here for you Chevy Duty fans first before I eBay it off. Fist 6K takes it, don't bother making an offer. Email me for some nice pic's of the truck if you're interested ttullio(at)direcway.com or call me a 937-787-9007.
    https://talk.classicparts.com/images/attachments/441ef6d708acc6af.jpg
