Does anyone know where or who to contact about a new guage cluster for my 77 chev truck. Every cluster that i have found has been cracked or broken due to the plastic being too old. Thanks
Wow the ones I found is because people did not take them out right or forgot to take screews out some where or over tighten them when put them back in. I had a quit a few. They can be fixed it the pieces are still there. You can use 73-80 clusters with the same gauges option as yours. As i.e. if you had three small gauges with big gas gauge then you can get one from 73-80 but has to be the same set up as your. If it did not have gauges then you gauges will not bolt in the cluster case. As far as I know the only place that might have them is GM dealer but the used parts place a parts truck or e-bay scrap yard.Would be the only places for the cluster case
