73-87 Frame Rivets Help
Discussion in 'Chassis & Suspension' started by Pontiac1976, Jan 29, 2011.
  1. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    73-87 FRAME RIVETS
    Has any one take out the frame rivets got new one from LMC.
    How did you go about in stalling them on the frame and frame brackets for the suspension.
    Or did any one just use blots for the rivets.
    All views Welcome and any tricks in this area are needed.
    Thanks in advances
  2. drabo
    drabo Member
    Patrick AFB, Florida
    Grade 8 bolts and loctite.
  3. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Thanks for your post. I started to do that with a few brackets but really like to try rivets. But for the rest that I want to replace, I was hope to find ways mount the rivets. I thinking about having the frame powered coated.
  4. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    BUMP :) still looking for info. thanks
  5. Vin63
    Vin63 Member
    SoCal
    It is a lot of work to re-rivet the frame and brackets. That was some of the hardest work I ever did in helping a friend with a restoration project. Here is a link to the stuff he used on his customer's antique frame. I only helped with one outrigger bracket and I was laid out on the floor done.
    http://www.bigflatsrivet.com/index.html
  6. LEYLAND
    LEYLAND Member
    Ontario, Canada
    use grade 8 bolts as mentioned above. guys abuse trucks in off roading situations that a normal vehicle would never see, chevy guys purposely drill out the rivets and replace them with bolts to eliminate weak spots. some have also welded their cross members solid to the frame...
    particularly around the steering box is a prime area for stress cracking. see link below for stiffening brackets.
    http://offroaddesign.com/catalog/steeringkit.htm
    good luck
  7. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Thanks for the help. The old 77 Heavy 1/2 fleet ( flat bed ) is a 2WD that does not see much use in off road :Dexcept some dirt roads on the way to a Drag race track with a trailer behind it :)
    I do love the 8 grade bolts I even put a few on the rear bump stops plates might be a little over kill.:rolleyes: I did not like the look of the bolts sticking out.:(
