73' chevy shortbed 4x4
Discussion in '1973-1987' started by seminole ndn, Sep 16, 2006.
  1. seminole ndn
    seminole ndn Member
    I've got some milemarker hubs and I'm trying to change the rotors there warped. I took the outter locking cap off 6bolts,clap ring off,gear and spring out.......now I'm stuck :confused:
    Thanks
  2. Heavy86Chevy
    Heavy86Chevy Member
    British Columbia Canada
    There will be a series of snap rings and special nuts that are removed with the special socket with 3 grooves in it....and bearings....be sure to remove carefully since reinstallation can be tricky and greasy...haha.. be sure to align the pin on the piece with the machined holes in it.. good luck
