'79 Sagging Cab
Discussion in '1973-1987' started by Newby, Oct 31, 2000.
  1. Newby
    Newby Member
    I just bought a '79 1/2 ton 4X4 short wide box and the cab is sagging on the drivers side. If you look at it from the front you can see a drop of about 3 inches. The bed is still level, it is just the cab. If you look through the rear window you can see just how much it saggs by the window trim of the canopy. Any ideas or sugggestions on what the problem is and a fix.
  2. Craig
    Craig Guest
    [font size=1" color="#FF0000]LAST EDITED ON Oct-31-00 AT 10:07 AM (CST)[/font][p]It sounds as if you need some new cab mounts.Give me a call we a sell a complete set for $69.95
    Craig Hager
    tech1@chevyduty.com
  3. BuffyPickup
    BuffyPickup Member
    Have you considered lowering the driver side so it looks level?
  4. i4544x4
    i4544x4 Member
    sounds like you need body mounts.Irecomend neoprene. thats what i did to cure the same problem
  5. truckie_ff
    truckie_ff Member
    Newby,
    I have a 79 also, I am not sure if the cab mount bushings would make a three inch drop or not, but none the less, it is worth looking at. You might also check to make sure your cab mounts themselves are not broken. ( the mounts are attached to the frame, and "L" shaped braket). Good Luck!!!
    Truckie
    If your mirrors aren't shaking, You've been taken!!!!!!!
