8 lug conversion
Discussion in '1973-1987' started by nerfherder78, Feb 27, 2004.
  1. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    i'm planning to replace my 5 lug 10 bolt rear with a 8 lug 14 bolt FF axle over the summer. What's the cheapest way to convert the front end to 8 lugs? Is there any difference between the spindle on my truck and a C20? (I know the wheel bearings and ball joints are different) I looked in the ##### catalog and they only list a spindle for C20's. Is it possible to just swap the steering knuckle off a C20?
    thanks in advance
    Craig
  2. oldpickup
    oldpickup Member
    Franklin USA
    your best bet would be to find a donor truck and swap the whole axle assembly.
    Jason Richardson
    1975 K20
    1980 K30
    1976 K20
  3. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    [updated:LAST EDITED ON Mar-04-04 AT 11:41 PM (CST)]I'm already planning to go to the junkyard to check and see, I don't have the money to go out and buy a whole donor truck though. Just wondering if anyone has attempted this.
  4. oldpickup
    oldpickup Member
    Franklin USA
    it has been tried. the later models had the 10 bolt front axle but i cant remember if the tube size was the same. seems i remember someone just changing the spindles hnd hub, they take the same brakes so you shouldnt have to change that. check on that and let me know what you find out.
    Jason Richardson
    1975 K20
    1980 K30
    1976 K20
  5. 74X4Burb
    74X4Burb Member
    Fort Shaw U.S.A
  6. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    C10 = 2 wheeler
    sorry i didn't make that clear
  7. texisdog
    texisdog Member
    Mesa U.S.
    charlie, Go to www.colorado k5 and check their how to do list. It gives step by step and part #. Real good bunch of folks.
