80-87 FullSize Parts Wanted, List
Discussion in 'Truck Parts Wanted' started by GonicGM, May 27, 2011.
  1. GonicGM
    GonicGM Member
    Seacoast New Hampshire
    See revised list below
  2. GonicGM
    GonicGM Member
  3. GonicGM
    GonicGM Member
    Updated list:
    Small block intake manifold vacuum fitting from behind carb from loaded mid 80's 4bbl C/K
    Tall tan kick panel(any 81-87 old style) drivers side needs to
    be non A/C.
    Tan manual window door panels (clean) (81-86 old style) Scottsdale, or
    better yet Silverado/Sierra Classic
    Tan door panel pull straps and map pockets (81-86 old style)
    Tan OEM floor mats
    Clean pair (or individuals) of rear brake drum backing plates for 84-87 1
    ton GM, some 88-91 R/V may be the same. These have the snap in style ebrake cables. Can be from 14 bolt FF SRW, DRW or Dana 70.
    Dual tank harnesses, firewall back, RH fuel lines(any 81-91 old style)
    OEM 30 Series Tailgate Lights and Harness
    Camper Special stuff, Tie downs, dual battery harness & relay(73-91 old
    style)
    Caps, Warn/OEM manual locking hub, Dana 60, 3/4 turn, fairly clean.
    Silverado 30 fender emblems with studs in tact (81-91 old style)
    Scottsdale 30 fender emblems with studs in tact (81-91 old style)
    Factory Under bed exhaust heat shields
    Door Jamb rubber seals from Diesel Truck/Silverado/Sierra Classic(81-91 old style)
    Rear spring shackles from 1973 +/- (folded with two rivets)
    Doug Thorley Tri-Y headers for small block or big block
    OEM Front bumper guard (bumperette) for 81-87, passenger side.
    stock 10 bolt/dana 44 front u-bolts, 2.75" or 3.00" tube
    Clean OEM 8 lug white rims, Suburban spares ideal.
    New England only:
    OEM Doors in Code 72 Apple Red(any 77-91 old style)
    OEM Front fenders in Code 72 Apple Red(any 81-91 old style)
    OEM grey cardboard liner, behind seat.
    85-88 factory dual exhaust, any pieces, from carbureted truck.
    Front bumper black plastic lower spoiler/air dam/air deflector, 4x4 or 4x2. (81-91 old
    style)
    Frame mounted receiver trailer hitch.
    Clean OEM 8' bedsides with square fuel filler door, 81-87
    Firewall insulator, non-A/C from 6.2 Diesel Truck(81-91 old style)
  4. GonicGM
    GonicGM Member
    ttt
    revised list, again.
  5. GonicGM
    GonicGM Member
    bump to top
  6. GonicGM
    GonicGM Member
    bump for revised list.
  7. GonicGM
    GonicGM Member
    updated again
