a/c bracket
Discussion in '1973-1987' started by toby340, Oct 17, 2006.
  1. toby340
    toby340 Member
    i have an 82 c-10 and i swapped the 305 with a mild 350 with hooker headers . the truck came with a/c ,the pancake style mounted on the drivers side.is there a special bracket that bolts to the heads ,the original does not fit,even the one hooker sent with the headers.thanks for any info or pics!:confused:
  2. Heavy86Chevy
    Heavy86Chevy Member
    British Columbia Canada
    does the bracket fit around the header? if it does and it is lined up just measure and cut some spacers and use longer header bolts...
  3. toby340
    toby340 Member
    yes,i had to grind to make it fit ,but im still working on your idea with the spacers,thanks!
  4. Heavy86Chevy
    Heavy86Chevy Member
    No Problem man glad i could help...
