adjusting valves on 1965 Chev 327
Discussion in 'Performance, Engine, and Transmission' started by PH3690, Jul 7, 2012.
  1. PH3690
    PH3690 Member
    Can someone explain to me how to adjust valves on a 65 Chev 327?
  2. Illsaveyou
    Illsaveyou Member
    Northern California Sacramento area
  3. JohnB
    JohnB Member
    Indianapolis, IN
    Assuming you have hydraulic lifters. Solid lifters is a different issue.
    With engine running, lay rags over rocker arms to keep oil from spraying all over. Back off rocker nut until it clatters. Tighten until quiet, then tighten 1/4 turn at a time, pause until engine smooths out. Repeat until 3/4 turn. Repeat on all cylinders. Book calls for 1 full turn but we found 3/4 worked better.
    I was a "Certified" Factory Trained Technician back in the 1060's.
