Advice needed identifying Edelman brake fittings number dual cyl. CPP drum/drum setup
Discussion in '1947-1954' started by Blueflame236, Nov 22, 2010.
  1. Blueflame236
    Blueflame236 Member
    Norway
    Hey guys
    1950 1/2 t. truck with standard Huck drum/drum brakes and standard brakeline setup.
    These brake plews are hard to get here in Norway so i have to order them directly from the US.
    I need some help to find out excactly wich of the Edelman fittings i need (Edelman part numbers please) when installing the new CPP dual master cyl. and fore the rest of the brakelines. I have bought 2 10 LBS residual valves wich i need to install in the brakeline sirquit aswell. One in the rear and one in the front.
    I am not shore if you can buy a complete fit in brakeline set for the 1/2 t. truck that has the dualmaster setup, or if i have to buy the brakelines and fittings sepratly.Then bend them my self make the koplings ready and screw the flew fittings in there places?
    Attach the Edelman catalog;
    http://www.plews-edelmann.com/brochure.cfm?brochure=1869&location_id=2516
    Thanks for your help Martinius.
    Attached 10 LBS Residual valve i have.
