advice on radiator
Discussion in '1947-1954' started by 53joe, Sep 10, 2010.
  1. 53joe
    53joe Member
    Hello
    I'm new to the board and need some advice. I'm restoring a 53 chevy pickup and have a bad radiator. I had a quote on replacing the core on the original radiator for $360.00 ( is this expensive?) or I can buy a new aluminum radiator ( 3 core) for $229.00. What would you guys do? I was told the aluminum radiator would cool better but won't last as long. Any advice would be very appreciated.
  2. ccharr
    Welcome Aboard Joe, enjoy your ride.
    Cost and your pocket book mandate what you do, isn't there someone around that could rebuild the old one and add a row to it?
    For me the old look stays, but are you going to Hot-rod or make a boom out of it, why have it look original. Your Truck, your Dream.
  3. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    If this truck is going to be a weekend toy then the Alum. radiator will probably last you a life time and cool just as good if not better than brass but then again as Charles said you have to decide what look you are trying to achieve. If you go aluminum however make sure you get one with welded tanks and not epoxied.....Big Tim :cool:
  4. Fern53
    Fern53 Member
    When I had my '53 recored it was $350 at a local shop. So I'd say that price is fair.
  5. 48aero
    48aero Member
    Tyler, TX
    If you use the aluminum be sure to use extended life anti-freeze to protect against dissimilar metals. I bought one of the
    champion ones on ebay and just put it in, bolts right in. (229.) Jesse
  6. 53joe
    53joe Member
    Thanks guys. Decided to fix the original and I'm taking it in today. Wanted the original Harrison Radiator name on it. Will let you know how it turned out.
  7. codyfox
    codyfox Member
    Copperas Cove , TX
    Radiator
    I went ahead and bought me one from LMC with everything I needed with it and I believe with parts, etc...it was $330 total..Somewhere in that range. Well worth it..
    Part # Description Qty Price Total Status
    32-2910 RADIATOR 1 279.95 279.95 In Stock
    30-0070 RADIATOR MOUNT BOLT KIT 1 1.95 1.95 In Stock
    32-0012 RADIATOR CAP-4 LB 1 3.95 3.95 In Stock
    32-0080 RADIATOR DRAIN TAP 1 3.95 3.95 In Stock
    30-3426 CLAMP-RADIATOR HOSE4REQ 4 0.95 3.80 In Stock
    30-0262 BOLT A/ 1 0.45 0.45 In Stock
    30-0656 FLATWASHER A/R 14 0.25 3.50 In Stock
    30-0626 LOCKWASHER A/R 14 0.35 4.90 In Stock
    30-0845 NUT A/R 4 0.65 2.60 In Stock
    Cody
