Advice wanted dual intake versus carbs choice ?
Discussion in '1947-1954' started by Blueflame236, Jan 8, 2011.
  1. Blueflame236
    Blueflame236 Member
    Norway
    There are some different aftermarked dual intakes available for the 235 Ci staright six cyl. engines. To mention some of those used most are Offenhauser,Fenton, Tattersfield ect.
    For 235 CI ; Offenhauser intake measures ;
    The carburetor port diameters are 1.700 in. Carb studs 2-15/16 on center
    The intake port diameters are 1.550 in.
    For 235 CI; Fenton measure; Carb studs 2-15/16 on senter.
    This intake will use (2) of the bigger base carbs typical of 54-62 Chevys. Carb brands that are used are ; Stromberg,Holley,Rochester,Carter,Zenith
    Question;
    I would like to know wich carb model and brand will fit directly on the intake
    (carb studs have 2.15/2.16 on senter) and give the best performance/power?
    Tell us your experiences, thank you Martinius.
