Aftermarket steering stem what drop to use?
Discussion in '1947-1954' started by Ricos54, Dec 11, 2013.
  1. Ricos54
    Ricos54 Member
    CA
    I'm getting ready to buy a chrome steering stem from Summit racing for my 54 chevy truck. Was wondering anyone that bought a aftermarket steering stem for there truck what drop did you use? They range from 0-3.5 inches. Not sure what will work best and needed some help. I know it's a matter of preference, but hoping I could buy once. So any inside would be great.
    Thanks,
    Rico
  2. 1952
    1952 Member
    I used a flaming river steering column with a firewall brake booster instead of leaving the brake booster on the frame. Because of the brake pedal assembly in the cab I used a 2 inch drop from the assembly and for good measure I used the original column clamp with minor adjustment as well. So now the column is locked in tight, at the floor, the brake assembly and lower dash
  3. ol' chebby
    I like mine hugged up tight to the bottom of the dash. It gets the wheel out of your lap. With a tilt, high mount and then the wheel adjusts to a more vertical position.
