Are brake parts same for ford and GM?
Discussion in '1947-1954' started by Bilbo, Jan 8, 2011.
  1. Bilbo
    Bilbo Member
    Magnolia, Texas
    I need the parking brake arms for inside my rear drum brakes. Currie has arms listed for ford 9" rear end.... Would the Bendix parts be the same for my GMC? If not, does anyone have said parts available?
  2. 1951chevy1ton
    1951chevy1ton Member
    Near Sleepy Eye MN
    parking brake arms
    I have the park brake arms from a 48 one ton if they will work, interested, let me know
  3. Bilbo
    Bilbo Member
    Magnolia, Texas
    Sorry, the earlier models have a different kind of brakes. The '52 has Bendix brakers just like all the way up to the '60's
  4. Flashlight
    Flashlight Member
    One Ton,
    Unbelievable, you sent the clevis on Saturday from Minnesota and it arrived in TN on monday. It is the right clevis and your check went out yesterday. I looked for a couple years to find those P-brake speader bars. Finally found them in a 55' sedan. I should of gone on here first.
    Flashlight
  5. Bilbo
    Bilbo Member
    Magnolia, Texas
    I'm still needing the spreader bars, and brake arms that attach to the brake shoe, for the park brake if anyone has such parts. I'm sure they are the same all the way up to the '60s......
  6. Elky67
    Elky67 Member
    Bavaria South
    Hi Bilbo,i have my rear brakes just half assembled,would it help,if i make a drawing,so you could go to your local shop,to have them cut out,or even do it yourself? All you need,is lets say a 5mm steel plate and an angle grinder. Just give me a note,and i'll draw them!
  7. johntaps
    johntaps Member
    No... there is vast difference between ford and GMC parts. So you cannot use the ford parts instead of GMC.
  8. MotherTrucker
    MotherTrucker Member
    GMC and Ford
    UHHHH,,is my GMC parts the sames like Fords be?
    If that wernt such a stoopid qeston,,id half to laff.
    Does a 14 inch tire work on a 15 inch wheel?
  9. johntaps
    johntaps Member
    Well said...it will never works :)
  10. Bilbo
    Bilbo Member
    Magnolia, Texas
    Did you even LOOK at what I asked? These are simple hardware parts, that very likely may be the same, although most Ford parts won't fit GM. Since the brakes are made by, in the case of GM, Bendix, and since I do not know who makes the brakes for Ford, it was a legitimate question....:mad:
  11. ol' chebby
    I do know that the hood hinge bolts are exactly the same from Ford and Chevy on a 53....I wouldn't be surprised to find that more things cross over.
  12. sweet70beast
    sweet70beast Member
    Rexburg Idaho
    Well, atleast you can spell MotherTrucker right.
    And yes it was a legit question.
  13. Bilbo
    Bilbo Member
    Magnolia, Texas
    Thanks for the support... We tell everyone here, "There's no such thing as a stupid question", but apparently some don't subscribe to that Philosophy. I don't get offended easily, but for some reason That did it... I'll bet I'll get over it though ;)
  14. Bilbo
    Bilbo Member
    Magnolia, Texas
    Hey '70 Beast, got a picture of that '50 GMC you have listed on your posts? It happens, I've got a '50 GMC as well. :cool:
  15. ol' chebby
    If you found an old time mechanic.....from back when things got fixed, not replaced, he may be able to advise you on this. You could also find someone from Cuba, they are the craftiest I have ever heard of.....they have to keep their ides going no matter what. They have parts from all manufacturers on a single car.
  16. vwnate1
    Bilbo
    I hope so ! .
    Typically when ignorant responses are made , it's because the person is afraid his ignorance will show so he tries to deflect it to you....
    No worries , THERE ARE NO ' stupid questions ' ! I know , I ask some really bone headed ones but so what ? .
  17. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Those are strut bars, you may even want to look at old mopars as well,,,;)
