Basic question
Discussion in '1947-1954' started by dorcutt, Feb 27, 2009.
  1. dorcutt
    dorcutt Member
    Keep the truck in VT
    Basic question, I need to get the bolts out on fenton headers so I can hook up my carb heat tubes. There being stubborn. they appear to be steel lines as I havn't chewed them up yet. The header are off of the truck at the moment. Any suggestions. Thanks, Dave
  2. Kens 50 PU
    Patience is the key!
    Soak them with a good penetrating oil. Kroil is a good one. Then soak them again. Do not apply too much pressure trying to break them loose or you will break them. Did I mention soaking them? That's the key, my friend.
  3. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Pb blaster
    Kens 50 PU forgot to mention that you soak them for DAYS. let it set and don't get in a hurry. I usually go for two with multiple applications each day. PB Blaster hasn't let me down yet.
  4. Wolf
    Wolf Member
    Kansas
    I also have used PB blaster, but i have heard good things from the other also. I sprayed my shock bolts bout 2 times a day for a week, and when i went to take them off.... they were good to go
  5. vwnate1
    When Penetrating Rusty Fasteners
    Remember to shock the parts by tapping with a metal object each time you add a new spray of your favorite penetrant , DON'T tap on the threads ! :eek:
    The little shock you impart , actually helps the penetrant wick in between the rusty parts .
    Sometimes tightening the stuck fastener one flat will help it to creep in too .
    Patience ! :p
  6. dorcutt
    dorcutt Member
    thanks to all for the suggestions. I continue to learn from this forum, it great. Dave
