bed wood FINALLY installed
Discussion in '1960-1966' started by rustbucket, May 8, 2009.
  1. rustbucket
    rustbucket Member
    New Braunfels USA
    FINALLY... took my daughter and I two solid days but, we got the wood installed. Have to go back tomorrow and tighten up the bolts but other than that, that part is done.
    I do have one question though...
    I have a slight bow in the front part of the bed that is causing a larger than I want gap in the edge of the wood at the tailend. What can I use to somehow squeeze the two ends together...if that makes any sense...
    I was thinking 6' furniture clamps (if they come that big)
  2. HookedUpGTP
    HookedUpGTP Member
    Ladson, SC
    Didn't your bed strips pull in the bow on the front when you installed them? I used a 2X4 from under the front of the bed to wedge it back slightly as I tighened everything up and that pulled the front in straight.
    The wood looks great! Good Job!
  3. rustbucket
    rustbucket Member
    New Braunfels USA
    nope, the strips didn't pull in the bow. i must just use a 2x4 block and a hammer on the outside of the front bottom of the bed and see if I can "tap" the bow out. It is only about 1/8"....maybe a 1/4" at the most.
    we haven't tightened the bolts yet so everything "should" move. (famous last words...)
  4. leavmeb
    leavmeb Member
    Central Maine
    Rustbucket
    How about a rachet strap?
  5. rustbucket
    rustbucket Member
    New Braunfels USA
    leavmeb... that will work!! thanks!!!
