Big Block in 62 SB
Is it a BB 400 or SB 400? Do you currently have a small block v8 or the inline 6? Is the tranny a short shaft or long shaft? We need more info to help you out.
It's a BB 402. It used to have a inline 6 cylinder. I don't know if it is a short or long tail shaft. Which one would be easier?:cool:
There is no bolt in kit for a big block that I know of. To put in a small block all you have to do is change the pearches/motor mounts. Correct me if I'm wrong but I thing the short shaft 400 will fit without cutting the driveshaft.
Finding exhaust headers that fit will be a problem...
The driveshaft should be measured for after the motor & trans are in. Shortening a drive shaft isn't all that expensive by a good driveline shop. Around $100 ...
dv
