bud45
Hopefully, this is the right forum/area for this question: I have a '65 283 in my '69 GMC. I use a high quality oil filter (synthetic media) and Castrol 5W30 oil, with one quart of Lucas Oil Treatment. After about 500 miles after the oil changes, the oil is black. Now, this engine doesn't have a PCV valve, just a breather on the oil fill tube and at the rear, behind the intake manifold, an elbow with a "slobber tube" attached going down below the oil pan. I added the tube because oil residue was dirtying the engine at the rear, making me think I had a rear oil seal leak at first. Would it NOT having a PCV valve system cause the oil to be black, or do I need to put a better, tighter breather at the oil fill tube?
I usually change oil between 2500 & 3K miles, but this has me a little concerned. I thought of doing an oil analasis & seeing if the oil is doing it's job (capturing dirt) or if it's gas byproducts... but this engine has been recently rebuilt, possibly within the last 5-6K miles and then was driven little before being transplanted into my truck.
Another thought: I have a carb from a '66 283 that has a PVC valve at the lower rear of the carb body, which would just take a short piece of my "slobber tube" to connect it to the elbow at the rear of the engine. Could rebuilding this carb (just for newness-sake) and installing it help the oil situation? Or could it contribute to gas byproducts being intro'ed into the lube system?
Thanks for the help
Thanks for the help
