Blazer Doors
Discussion in 'Blazers/Jimmys/Suburbans' started by 69Blazer, May 19, 2001.
  1. 69Blazer
    69Blazer Member
    Does anyone know if you can cut truck doors to make them Blazer door. If so can you please let me know the proper procedure.
    Thank You for any information that you have
  2. Michael_A_Price
    Michael_A_Price Member
    Dont go there yet. I am looking into picking up a pair of 71 4x Blazers this comming weekend. I hope to make one good one out of the pair but will have plenty of body parts left over. The bodys are good just lots of detail parts and drivetrain damage on one. I'll reply again when I know more for sure.
  3. CASurfer
    CASurfer Member
    Sure the doors will work, the plastic cap at the top of the vent window pillar will cover the cut on the front and the rear felt window channel will cover it at the rear. I m doing the same thing on my '71 blazer
  4. LeRoy
    LeRoy Member
    One more thing that's different is that Blazer doors have a reinforcing plate behind the door hinges. You need that plate when the tops off and not helping the tub structurally. Pretty soon the hinges will crack around the base without the plate
  5. CASurfer
    CASurfer Member
    Does this plate go on the inside of the door shell or outside?
  6. marvin
    marvin Member
    payette usa
    do you have a extra set of latches for the back hatch for the 1970 blazer. mgramps@fmtc.com
  7. shopguys
    shopguys Member
    lake srevens us
    OUTSIDE!:) THEY ARE SPOT WELDED TO YOUR BLAZER DOORS. THERE ARE ALSO LITTLE RUB PLATES TOWARD THE TOP OF YOUR DOORS & ON THE JAM OF YOUR BODY.
  8. sean71k5
    sean71k5 Guest
    I have also gone the route of curtting truck doors to fit my '71.
    Where can I get the plastic caps that go on top of the vent window pillar?
    Please help! I cant find then anywhere!
