my blinkers dont work and i cannot find the mechanical part to them, i found everything else but the actual mechanical part. someone help please:7
Hi six two ! What do you mean by the mechanical part? The stuff inside the column ? And, when you said you can't find it, did you mean to purchase ? Or,, you can't find it on your truck ??
Hi 62Chevyman, I also have a 62' chevy, the blinker switch is mounted on top at the base of your steering column. There is a cable that runs from the turn signal cam, down to the switch at the base of the column. Also before I replaced my wire harness the flasher needed to be wiggled, or pushed in + out sometimes to get it to work. Also check your grounds,and the light bulbs. Does the green light, light up in your dash for either side? David
