The rain moved on pulled motor & trans numbers on block at starter are as follows con f 232 head numbers as best i can tell b59 845 856 i think this is the stock 235 engine. Completely locked up poured a quart of water out of trans the engine may not be worthy.Blasted first member today i plan to paint frame with duplicolor high heat plastic coat as i go.I forgot how clean sand blasting was.
