I'm going to pop the body off my 72 Blazer to install a new body mounting kit nuts, bolts etc. My question is should I go with original rubber or the polyurethane type? anyone tried either? 7D2N
Hey 7d2n The Rubber is going to be the original set up it is going to be softer more cushy mount...The Poly is going to be stiffer mount but will out last the rubber by far.
Bad Brad, Thanks for the response, would you know if it requires to lift the body more than a couple of inches of the frame, and do you think it could be done with floor jacks ? Thanks 7D2N
