Bolt Set??
Discussion in '1955-1959' started by DwntwnKokomoJoe, Feb 27, 2008.
  1. DwntwnKokomoJoe
    DwntwnKokomoJoe Member
    TX
    Hi,
    Does anyone know where I can buy a complete bolt set for a 1957 GMC 100 series? I have most of the original bolts but they are easy to break. Any information would help.
    Thanks,
    Chris
  2. Kens 50 PU
  3. DwntwnKokomoJoe
    TX
    Thanks for that site, I think they are going to have exactly what I need. By the way I have one other problem. I can't get my transmission to go in all the way. Its the same one I pulled, cleaned and put back together. When I go to install the tranny it won't fit right. Needs about an inch and a half to two inches for proper placement. Do you know what I'm doing wrong?
    Thanks,
    Chris
  4. Bill Hanlon
    Did you align the clutch disk?
  5. DwntwnKokomoJoe
    TX
    I'll check the alignment on that and keep working at it. I'll probably have to go in and make sure all the parts are in the proper place and make sure nothing has shifted around in there. I just recently moved the truck (on a trailer) to another location so something might have been moved.
    Thanks,
    Chris
