Can someone please tell me if the brake hoses on the front are suppose to run one the outside or inside of the upper ball joint, on a 85 2 wheel drive with 2" drop spindle. The hose was run on the outside before I took it off, and it looked like the hose was being pressed closed between the upper control arm and the top of the spindle. so I was thinking the correct way would be behind the upper ball joint. thanks for any feed back on this issue.
