brake lights%3F
Discussion in '1973-1987' started by oLyMpUs, Sep 8, 2005.
  1. oLyMpUs
    oLyMpUs Member
    Kc USA!!!
    i have a 81 chevy c10 and i have all light but brake lights !! i have replaced the bulbs and check all the fuses can someone please help thanks
  2. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    Have you checked the stoplamp switch? (There's a bracket bolted to the pedal that makes contact with it) If only the brake lights are out that is most likely the problem, otherwise it might be a bad wire somewhere.
  3. towman1970
    towman1970 Member
    marquette united states
    how did you check the fuses did you just pull them out and visually look at them or use a test light to check each side of the fuse you mau not be getting power to the fuse itself or a bad wire from the fuse block to the brake lights or maybe a bad ground i know i despise wiring it sucks lol good luck
